Named path parameters
Instead of using hard coded paths in the URL of the http in node, you can use named parameters. The provided values can be accessed from msg.req.params.
Consider the following URL pattern: /:solution/:verb/:template/:section
Copy
http://127.0.0.1:1880/pod/render/site/dashboard
Fragment of the resulting msg object:
Copy
  "msg": {​​​​
    "req": {​​​​
      "params": {​​​​
        "solution": "pod",
        "verb": "render",
        "template": "site",
        "section": "dashboard"
