Feature Mapping
This page provides an overview on how Workflow features/techniques map to their Node-RED equivelant. Some tasks can be mapped to standard features in Node-RED where others require third party nodes (for now) or are handled by Node-RED specific techniques.
Inputs
| Workflow plug-in | Node-RED node | Node Type | Note |
| Node JS Server Input | http in, http response |
STANDARD NODE-RED |
| Folder Capture | folder capture | OL FILES AND FOLDERS | |
| Folder Listing | folder listing |
| LPD Input | No alternative yet | Planned for OL Connect 2026.2. | |
| Create File | inject | STANDARD NODE-RED | |
| Email/SMTP Input | node-red-node-email | STANDARD NODE-RED | Needs to be installed separately. |
| FTP/SFTP/FTPS Input | ftp client | OL FTP PACKAGE | Use the List directory operation. |
| Telnet Input | tcp in, tcp out |
STANDARD NODE-RED |
| Input SOAP | node-red-contrib-soap | THIRD PARTY | |
Merge PDF Files |
| WinQueue Input | WORK IN PROGRESS | Planned for OL Connect 2026.2. | |
| Secure Email Input | node-red-node-email | STANDARD NODE-RED | Needs to be installed separately. |
| Begin Sub | Use Node-RED subflows or links | STANDARD NODE-RED | |
| InputErrorBin | catch | STANDARD NODE-RED | |
Serial Input |
| O365 Email Input | OL M365 PACKAGE | ||
| O365 One Drive | OL M365 PACKAGE |
Actions
| Add/Remove Text | |||
Advanced Search and Replace |
change |
STANDARD NODE-RED |
Barcode Scan |
Planned for OL Connect 2026.1, as a Document Boundaries option and extraction through scripting in DataMapper. | ||
Change Emulation |
Create PDF |
ps to pdf |
OL CONNECT PACKAGE |
In preparation for a new node supporting PDF operations, a PS to PDF endpoint has been added to OL Connect Server 2025.2. |
Database Query |
node-red-node-mysql (handles both MySQL and MariaDB) |
THIRD PARTY |
Planned for OL Connect 2026.1 and OL Connect Automate 1.1. A sample scenario on integrating an external database is outlined in Use External Databases. |
node-red-node-sqlite |
THIRD PARTY |
See above |
node-red-contrib-mssql-plus |
THIRD PARTY |
See above |
Decompress file(s) |
node-red-contrib-zip |
THIRD PARTY |
Create and read ZIP files. |
Digital Action |
External Program |
exec |
STANDARD NODE-RED |
HTTP Client Input |
http request |
STANDARD NODE-RED |
Load External File |
read file |
STANDARD NODE-RED |
Logger |
debug |
STANDARD NODE-RED |
Mathematical Operations |
jsonata in change or script in function nodes |
STANDARD NODE-RED |
Open XSLT |
THIRD PARTY |
PDF/A-3 Attachments |
Planned for OL Connect 2026.2 as a native feature in OL Connect. | ||
Push to Repository |
use third-party database integration nodes |
THIRD PARTY |
Use alternative database, for example a custom schema in Maria DB, as described in Use External Databases. |
Rename |
file operations (move) | OL FILES AND FOLDERS | |
Run Script |
function |
STANDARD NODE-RED |
change |
STANDARD NODE-RED |
Send to Folder |
Set Job Infos and Variables |
change |
STANDARD NODE-RED |
SOAP Client |
Standard Filter |
Translator |
XML/JSON Conversion |
xml |
STANDARD NODE-RED |
OL Connect
Create Print Content |
paginated content |
Create Job |
paginated job |
Create Output |
paginated output |
Create Email Content |
Render Email Content |
email content |
Download EML |
Use file store download. |
Create Web Content |
html content |
Execute Data Mapping |
data mapping |
Separate nodes, previously integrated in Execute Data Mapping for Workflow. |
data get |
Update Data Records |
data update |
Set Properties |
set properties |
Retrieve Items |
query items |
All in One |
all in one |
File Store - Delete File |
file delete |
File Store - Download File |
file download |
File Store - Upload File |
file upload |
Create Preview PDF |
preview pdf |
preview image |
Generates a rasterized image of a template (print/web/email). | ||
Mark Content Sets for Deletion |
Create PDF/VT |
| Merge Jobs |
Process Logic
Branch |
Use wires to branch out |
STANDARD NODE-RED |
Comment |
comment |
STANDARD NODE-RED |
File Count |
File Name Condition |
switch |
STANDARD NODE-RED |
File Size Condition |
switch |
STANDARD NODE-RED |
File/Folder Condition |
Go Sub |
Sub flows |
STANDARD NODE-RED |
Loop |
Run Script |
function |
STANDARD NODE-RED |
Send to Process |
link, complete |
STANDARD NODE-RED |
SNMP Condition |
Text Condition |
switch |
STANDARD NODE-RED |
Time of Day Condition |
Send to Folder |
write file / send to folder |
STANDARD NODE-RED |
Available through various techniques. OL Connect nodes like all-in-one and paginated output allow for direct output to folder as zip or individual files. |
Delete |
file operations |
End subprocess |
This is an output anchor of an subflow. |
FTP Output |
ftp client |
OL FTP Package |
Use the Put operation. |
SFTP/FTPS |
ftp client |
OL FTP Package |
M365 Email |
olm365 email |
OL M365 Package |
M365 OneDrive |
olm365 one drive |
OL M365 Package |
Print using a Windows printer |
Planned for OL Connect 2026.1 and OL Connect Automate 1.1. | ||
Printer Queue Output |
Secure Email Output |
STANDARD NODE-RED |
Send Email |
STANDARD NODE-RED |
SOAP Client |
node-red-contrib-soap node-red-contrib-simple-soap |
THIRD PARTY |
Not validated by OL. |
Data splitters
Data splitters |
split, join |
STANDARD NODE-RED |
Convert data to JavaScript objects first. |
PDF Splitter |
Use a data mapping configuration. |
OL Connect Workflow Concepts
| Topic | Node-RED | Node Type | Note |
| Send Configuration | Deploy Option | STANDARD NODE-RED | |
| On Error Tab | catch node | STANDARD NODE-RED | |
| Select a sample data file | inject | STANDARD NODE-RED | For more information, see Sample data tactics for Folder Capture in OL Connect Automate. |
| Startup Process (part 1) | inject with schedule | STANDARD NODE-RED | |
| Startup Process to prepopulate variables | Use Environment Variables instead of loading a JSON/XML/INI file. Environment variables are read before the engine starts; a startup flow my have a slight delay. | ||
| Metadata | Work with the JavaScript objects in the msg object. |
STANDARD NODE-RED |
