System Variables
In OL Connect Workflow, system variables (prefixed with a %) can be inserted into scriptable fields to retrieve and insert job, process, and date-related values. They are commonly used to create timestamps, build date-based batch strings, or return information about the current job file.
In OL Connect Automate, the same information is exposed differently: either through msg properties or via JSONata expressions. The table below maps OL Connect Workflow’s system variables to their equivalents in OL Connect Automate.
  • File-related variables are typically available under msg.file when using the folder capture or folder listing nodes.
  • Date/time values can be generated with JSONata’s $moment() functions.
For example, the following JSONata expression inserts a formatted date string:
$moment().format("YYYYMMDD_hhmmss")
This outputs a value like:
20240708_043210
The image below illustrates how a Change node can be used to insert a system-variable equivalent into a custom message property. In this example, the JSONata expression shown above is evaluated to generate a formatted timestamp, which is then stored in msg.myTimeStamp.
Setting msg.myTimeStamp using a JSON expression.
For more details, see JSONata for dates and timestamps and other JSONata expression samples.
System Variable Mapping
Workflow Variable Description Automate Equivalent
%o
Original file name with file extension.
msg.file.basename: Automatically populated by the Folder Capture node under msg.file.
"path": "C:\\workspace_olca\\commingling\\trigger-file\\in\\20250815_043836\\20250815_043836.trigger",
"folder": "C:\\workspace_olca\\commingling\\trigger-file\\in\\20250815_043836\\",
"basename": "invoice.xml",
"name": "invoice",
"ext": "xml",
"size": 2,
"date": "2025-08-15T14:38:36.810Z",
"event": "create"
When using the Folder Listing node set Output option to Array of Objects.
%a
Job file last modified date.
See %o: msg.file.date.
%c
Content of the job file in its original format.
Use read file node to read the data into msg.payload.
%F
Job file path and name.
See %o: msg.file.path.
%f
Job file name including the file extension.
See %o: msg.file.basename.
%z
Job file size in bytes.
See %o: msg.file.size.
%O
Original file name without extension.
See %o: msg.file.name.
%y
Current year.
JSONata expression:
$moment().format("YYYY") or $moment().year()
%m
Current month (numeric).
JSONata expression:
$moment().format("MM") or $moment().month()
%M
Current month (text).
JSONata expression: $moment().format("MMM")
%d
Current day (numeric).
JSONata expression:
$moment().format("d") or $moment().day()
%D
Current day (text).
JSONata expression:
$moment().format("dddd")
%I
Current day (short text).
JSONata expression:
$moment().format("ddd")
%h
Current hour.
JSONata expression:
$moment().hour() or $moment().format("hh")
%n
Current minute.
JSONata expression:
$moment().minute() or $moment().format("mm")
%s
Current second.
JSONata expression:
$moment().second() or $moment().format("ss")
%v
Current millisecond.
JSONata expression:
$moment().format("SS")
%r
Run mode
%u
Unique 13-char.
JSONata or function node:
$join([0..16].$substring('ABCDEFGHIJKLMNOPQRSTUVWXYZ', $floor($random() * 27),1))
%U
Unique 36-char.
Create GUIDs via the function node by adding a module like uuid.
%t
Current temp folder.
%e
Current metadata file name.
%E
Current metadata path.
%w
Current process name.
Not available, manually set a property via change node like msg.processName or msg.flowName.
%i
Current loop iteration index.
Within a split/join combination: msg.parts.index
