Image Formatting dialog
The Image Formatting dialog is accessible by selecting an image in the template and then selecting Format > Image in the menu.
All settings in this dialog are in fact CSS properties. Cascading Style Sheets (CSS) were originally designed for use with web pages: HTML files. Since Designer templates are HTML files, they are styled with CSS. To learn how to use CSS in the Designer, see Styling and formatting and Styling templates with CSS files. For information about specific properties and their options, see MDN Web Docs - CSS Reference.
For more information about the use of images, see Images and Styling an image.
Image Tab
General group:
Width: Set the width of the image in measure or percentage. Equivalent to the CSS
widthproperty. -
Height: Set the height of the image in measure or percentage. Equivalent to the CSS
heightproperty. -
Angle: Set the rotation angle of the image in clockwise degrees. Equivalent to the CSS
transform:rotateproperty. -
Corner radius: Set the radius of rounded border corners in measure or percentage. Equivalent to the CSS
border-radiusproperty. -
Display: Use the drop-down or type in the value for how to display the image. Equivalent to the CSS
displayproperty. -
Fit within frame: Use the drop-down to set the image's object-fit property. The options are:
Contain (default): Scales the image to fit within the container, while maintaining its aspect ratio.
Scale down: Like 'contain', but if the image is smaller than the container it is not resized.
Cover: Scales the image to cover the entire container, cropping any parts that don't fit. The aspect ratio is maintained.
Fill: Stretches or compresses the image to fill the entire container, potentially distorting the aspect ratio.
None: Does not apply any scaling to the image.
Source: Enter the web address or local file address of the image. Equivalent to the HTML
srcattribute. -
Alternate text: Enter an alternate text for the image. This is displayed in browsers and email clients when the image is loading or if the image cannot be displayed. It is also used for accessibility. Equivalent to the HTML
altattribute.
- Text wrap group:
- Float: Use the drop-down or type in the value for how to float the image, if the image is not in an absolute position (see Position, below). Equivalent to the CSS
floatproperty. - Clear: Use the drop-down or type the value to clear pre-existing alignments. Equivalent to the CSS
clearproperty.
- Positioning:
Position: Use the drop-down or type in the value for the type of positioning for the image. Equivalent to the CSS
positionproperty (see Using the CSS position property).Top: Set the vertical offset between this image and its parent's top position. Equivalent to the CSS
topproperty.Left: Set the horizontal offset between this image and its parent's left position. Equivalent to the CSS
leftproperty.Bottom: Set the vertical offset between this image and its parent's bottom position. Equivalent to the CSS
bottomproperty.Right: Set the horizontal offset between this image and its parent's right position. Equivalent to the CSS
rightproperty.Z-index: Set the z-index of the image. The z-index defines in which order elements appear. Equivalent to the CSS
z-indexproperty.
Spacing Tab
Padding group: Defines padding (spacing inside the element) in measure or percentage:
- All sides: Check to set all padding to use the Top value. Equivalent to the CSS
borderproperty. - Top, Left, Bottom, Right: Set padding for each side. Equivalent to the CSS
border-left,border-top,border-rightandborder-bottomproperties.
Margin group: Defines margins (spacing outside the element) in measure or percentage:
All sides: Check to set all margins to use the Top value. Equivalent to the CSS
marginproperty. -
Top, Left, Bottom, Right: Set the margin for each side. Equivalent to the CSS
Border Tab
Same for all sides: Defines the border properties for all sides using the Top properties. Equivalent to the CSS
borderproperty. -
Top, Left, Bottom, Right: Each group defines the following properties:
Width: Specify the thickness of the border. Equivalent to the CSS
border-widthproperty. -
Style: Specify the style of the border such as
solid,dashedordotted. Equivalent to the CSSborder-styleproperty. -
Color: Specify the color of the border: select a named color (defined in the Colors Properties) from the drop-down, or click the colored square to open the Color Picker dialog (Color Picker). Alternatively you could type a name or value in the Color field directly. It must be a valid CSS color name (CSS color names), a hexadecimal color code (HTML Hex Color), an RGB color value, for example
rgb(216,255,170)or a CMYK color value, for examplecmyk(15%, 0%, 33%, 0%). Equivalent to the CSSborder-colorproperty.
