Codabar Settings
Codabar barcodes support the following data: 0-9 - $ : / . + plus the optional specification of start/stop characters.
General group:
Position group:
- Codabar Properties group:
- Height: Enter the Barcode height in either metric (cm/mm), inch (in) or point (pt) values.
- Module Width: Specifies the width of the narrow bars. Changing this value to a higher value will generally make the Barcode bigger.
- Bar width ratio: Set the Barcode bar width.
- Default start symbol: Use the drop-down to select the optional Barcode start character, which defines the encoding mode.
- Default stop symbol: Use the drop-down to select the Barcode stop character, which defines the encoding mode.
Print human readable text: Check to add a textual version of the Barcode data.
- Display start/stop symbols checkbox: Adds the stop/start symbols to the Barcode text.
- Process Tilde:
