EAN-8 Settings
An EAN-8 barcodes are composed entirely of numerical data. It is comprised of 7 data digits containing the country/economic area code and an item reference code, with 1 following checksum digit.
General group:
Position group:
EAN-8 Properties:
Height: Enter the Barcode height in either metric (cm/mm), inch (in) or point (pt) values.
Module Width: Specifies the width of the narrow bars. Changing this value to a higher value will generally make the Barcode bigger. The EAN-8 barcode employs a module width between 0.27mm and 0.66mm.
Checksum: Use the drop-down to select how to deal with the Barcode checksum:
Ignore: Ignore checksum calculations.
Auto: Add a checksum character to the Barcode if the initial value does not validate. This is the default value.
Check: Verify the Barcode has a valid checksum.
Add: Calculate and add a checksum character to Barcode, regardless of current value.
Print human readable text: Check to add a textual version of the Barcode data.
- Process Tilde:
