GS1-128 Settings
GS1-128 is also known as "EAN 128", "EAN/UCC 128" and "UCC 128". This barcode type not only encodes data, but also provides a mechanism for defining the meaning (or format) of that data. It supports alphanumeric data and some predefined Function Codes. See the Wikipedia GS1-128 entry for more information.
General group:
Position group:
- GS1-128 Properties group:
- Height: Enter the Barcode height in either metric (cm/mm), inch (in) or point (pt) values.
- Module Width: Specifies the width of the narrow bars. Changing this value to a higher value will generally make the Barcode bigger.
- Check Digit marker: This character is used as a placeholder for the check digit, which we be calculated at runtime. The character must be expressed in Hex.
- Group separator: This character is used to define group separation points. The character must be expressed in Hex.
- Template: Specify an optional Barcode "template".
Examples:n13defines a numeric field with exactly 13 digits.n13+cddefines a numeric field with exactly 13 digits plus a check digit.an1-9defines an alpha-numeric field with 1 to 9 characters.
Elements can be combined using the '+' symbol.Print human readable text: Check to add a textual version of the Barcode data.
- Process Tilde:
Check this option to process tilde characters in the data as special characters.
With this option checked, any tilde that needs to be included in the output must be escaped by adding another tilde: ~~.
