Interleaved 2 of 5 Settings
Interleaved 2 of 5 barcodes are also known as "ITF" and "2/5 Interleaved". It is a numeric only barcode whose data must contain an even number of digits, as the barcode uses sequences of two digits interleaved with each other to create a single symbol. If the numeric data contains an odd number of digits, then a leading zero must be added to the beginning of the data.
  • General group:
  • Position group:
  • Interleaved 2 of 5 Properties group:
    • Height: Enter the Barcode height in either metric (cm/mm), inch (in) or point (pt) values.
    • Module Width: Specifies the width of the narrow bars. Changing this value to a higher value will generally make the Barcode bigger.
    • Bar width ratio: Set the Barcode bar width.
      • Print human readable text: Check to add a textual version of the Barcode data.
      • Placement: Use the drop-down to select whether to place the human readable text above or below the Barcode.
      • Font name: Use the drop-down to select the font with which to display the human readable text.
      • Font size: Enter a font size for the human readable text.
  • Process Tilde:
