US Postal Service IMpb Settings
US Postal Service Intelligent Mail Package Barcodes (IMpb) are used by the United States postal service for parcel deliveries. They contain parcel destination information along with other information about the delivery.
Note: Application Identifiers in the barcode value need to be surrounded by round brackets, otherwise the barcode will not be generated correctly.
For example, this value contains both a Postal Code Application Identifier (420) and a Channel Application Identifier 93: 420123459302234567890123456788. It should be written as follows: (420)12345(93)02234567890123456788.
More information about Application Identifiers can be found in the barcode specification here: https://postalpro.usps.com/shipping/impb/BarcodePackageIMSpec (8.0 Appendix D).
  • General group:
  • Position group:
  • USPS IMPB Properties group:
    • Barcode height: The height of the bars in the barcode, in inches (in). Value must be between 0.075 and 1.0 inches.
    • Module width: The thickness of thin bars in the barcode, in inches (in). Thicker bars are a multiple of this value. Value must be between 0.013 and 0.021 inches.
    • Text to barcode clearance: The space between the barcode bars and the top and bottom text, in inches (in). Value must be between 0.125 and 0.25 inches.
    • Text height: The height of the text, in inches (in). Value must be between 0.09 and 0.125 inches.
    • Line to text clearance: The space between the guard lines and text, in inches (in). Value must be between 0.031 and 0.04 inches.
    • Guard bar height: The thickness of the guard lines, in inches (in). Value must be between 0.031 and 0.063 inches.
  • Process Tilde:
