Installation prerequisites
Make sure your system meets the System requirements.
OL Connect Version 2025.2 can be installed under a regular user account with Administrator privileges., see User accounts and security.
OL Connect must be installed on an NTFS file system.
OL Connect requires Microsoft .NET Framework 4.5 (or later) already be installed on the target system.
Connect 2019.1 requires updated Connect License and/or Update Manager.
See Upgrading from previous OL Connect versions for details. -
In order to use the automation features in Version 2025.2, OL Connect Workflow 2025.1 will need to be installed.
This can be installed on the same machine as an existing PlanetPress® Suite 7.x installation or on a new computer.
For more information, please see Information about OL Connect Workflow.
If Workflow installation finds that .NET 4.6.2 (or later) is not already installed, it will prompt you to install this manually.
