Spot Color Settings
Note: This page is only available in the Enterprise edition of OL Connect.
The Spot Color Settings page is used to match Spot Colors contained within a job to the color settings available on the printer.
This option is only available
for AFP and IPDS print outputs, and requires a Printer Definition File (see Print preferences) that supports Spot Colors.
SpotColor Mapping table:
SpotColor Name column: This contains the names of the Spot Colors used within the job.
If the Spot Color were added to the job within Connect Designer, then those Spot Colors will be automatically included in the table. -
SpotColor Number column: This lists which Spot Color available on the printer is to be associated with the named Spot Color.
Add: Add a new association between a Spot Color in the job, and the Spot Colors options available on the printer.
Note: If the Spot Color was not added to the job within Connect Designer itself but are instead included within a external file (such as a PDF) added into the job, then care must be taken to ensure the Name added here is identical to the name reference used within that included file.
Delete: Delete a Spot Color association. -
Edit: Edit an existing Spot Color association.
