Writing scripts: tips and tricks
This topic provides some tips and tricks to use when writing template scripts.
For the basics, see Writing your own scripts.
All features designed for use in the Designer are listed in the Designer's API, with a lot of examples; see Standard Script API.
Tip: Hold Ctrl and hover over the script text to see hyperlinks, for example, to a variable declaration or a target resource.
Hold Ctrl and click, or press F3 to follow a hyperlink.
Followed links are added to the navigation history. Press Alt + Left arrow to return to the previous location, or Alt + Right arrow to return to the next location in the navigation history.
Tip: Scripts can be exported from one template and imported into another. See Import Resources dialog.
Looping over elements
If the selector of a script matches more than one element in a template, you may want the script to loop over them.
One way to do this is by setting the script's scope set to Each matched element (see Setting the scope of a script). The script will be called in a loop over the elements that match the selector of the script. It can access each matched element directly via the this object. For an example, see: this.
Otherwise, there are a number of iterator functions that you can use, such as each(), for(..in...) and for...of.
| Function | Description |
| each() | A generic iterator function, to iterate over the elements in the result set. |
| for(... in ...) | Iterates over the enumerable properties of an object, in arbitrary order. For each distinct property, statements can be executed. |
for...of |
The for...of statement executes a loop that operates on a sequence of values sourced from an iterable object. See Mozilla's documentation. Note: A for...of loop currently cannot be used in combination with 'const'. |
Retaining values between scripts
The context for user scripts does not reset across records. This means that if a script uses a variable that is not declared or initialized in that script, the variable retains its value from the previous record. This is by design. It allows you, for example, to maintain a running total across all records of a job.
If you want to make a variable global you should omit the const, var or let keyword:
Example: x = 123;
Note: Variables declared with const, var or let can only be accessed from the script (or function) in which they are declared.
Example: numbering optional elements in Connect template
Let's say there are a number of different, optional elements in the template. Whether the optional elements appear in the template depends on standard scripts. The optional elements that become visible should be numbered in sequence (1, 2, ...).
One solution is to assign a class, e.g. "opt", to all the optional elements in the template. In a Control Script, set a variable, e.g. "SequenceNumber", to 0:
sequenceNumber = 0;
Then create a script that has the opt class as selector. Set the scope to Each matched element. If an element is visible, the script increments the sequence number and puts it before the element.
if (!(this.css('display') == 'none')) {
sequenceNumber++;
this.prepend(sequenceNumber + ' ');
Obviously, this script should run after any optional elements have been made visible.
Note that this solution only works if the optional elements appear in the main flow of the template. It doesn't work for positioned elements.
Defining a function in a Control Script
Do you find yourself copy-pasting the same function into every new script? You can avoid this by defining your own function using a function expression:
fn = function() { … }
The function fn can be accessed from all subsequent scripts.
Tip: Define the function in a Control Script. Control Scripts are executed first, so the function will then be available in all Standard Scripts and Post Pagination Scripts.
Tip: Store Control Scripts remotely to make them available for use in multiple templates. See Using a remote Control Script.
