Information about OL Connect Workflow
If you wish to use OL Connect
Workflow (automation),
you will need to install OL Connect Workflow 2026.1 as well. Workflow 2026.1 is provided through a separate
installer which is available on CD or for download as follows:
- If you are a Customer, the installer can be downloaded from the Upland OL Connect Web Activations page: http://www.objectiflune.com/activations
- If you are a Reseller, the installer can be downloaded from the Upland OL Connect Partner Portal: http://extranet.objectiflune.com/
OL Connect Workflow can
be installed in parallel on the same machine as an existing PlanetPress®
Suite 7.x installation.
Note however:
- If both versions need to be hosted on the same machine, OL Connect Workflow 2026.1 must always be installed after the legacy PlanetPress® Suite 7.x installation.
- When uninstalling OL Connect Workflow 2026.1, you may be prompted to repair your legacy PlanetPress® Suite 7.x installation.
- If OL Connect Workflow 2026.1 has been installed alongside PlanetPress® Suite 7, Capture can no longer be used with Workflow 7.
- OL Connect Workflow 2026.1 and PlanetPress® Suite Workflow 7 cannot run simultaneously, since only one version of the Messenger service can run at a time. In fact, no two versions of Workflow can be run simultaneously on the same machine, regardless of versions.
- It is possible to switch between different versions running by shutting down one version's services and then starting the other. However, this is not recommended. There are no technical limitations that prevent processes from previous PlanetPress Suite Workflow versions (as far back as Version 4) to run on OL Connect Workflow 2026.1, removing the need to run both versions.
For more information on the licensing of Workflow 2026.1, please see Activating a License.
