connect()
Method that returns a new database connection object.
connect(url, user, password)
This method returns a new database Connection object after connecting to the given URL and authenticating the connection with the provided user and password information.
The function accepts arguments as described here: https://docs.oracle.com/javase/8/docs/api/java/sql/DriverManager.html#getConnection-java.lang.String-java.lang.String-java.lang.String-.
In the returned Connection object normally any public method should be available. The returned Connection object is described here: https://docs.oracle.com/javase/8/docs/api/java/sql/Connection.html.
Note: Make sure to close any Connection object created by connect() and any other closable resources created from the Connection instance (ResultSet, etc.).
url
String that represents a database url of the form jdbc:subprotocol:subname, e.g. 'jdbc:mariadb://localhost:3306/mycompany'.
The syntax will be specific to the database, or more precisely the JDBC connector. Currently Datamapper supports the following JDBC connectors:
com.mysql.cj.jdbc.Driver
sun.jdbc.odbc.JdbcOdbcDriver
com.microsoft.sqlserver.jdbc.SQLServerDriver
oracle.jdbc.OracleDriver
For older databases that only have an ODBC driver, a JDBC-ODBC bridge can be called using the jdbc:olodbc prefix.
The syntax is: db.connect("jdbc:olodbc:...", ..., ...);
Note that the JDBC-ODBC bridge can only execute a SELECT request; no write actions are allowed. For supported objects and methods of the returned Connection object, see JDBC-ODBC bridge: objects and methods.
This bridge replaces the legacy bridge which was deprecated. The legacy bridge can still be selected with jdbc:odbc:, and its functionality remains unchanged.
user
String that represents the name of the database user on whose behalf the connection is being made. This is used for authentication.
password
String that represents the user's password. This is used for authentication.
Example
Here's an example of how to connect to a MySQL database and retrieve a data value.
Note: As of OL Connect 2026.1 the JDBC database driver uses the same jdbc:mariadb connection scheme for both MySQL and MariaDB database connections, rather than jdbc:mariadb for MariaDB and jdbc:mysql for MySQL.
con = db.connect('jdbc:mariadb://localhost:3306/mycompany','root','admin');
statement = con.createStatement();
values = statement.executeQuery("select * from datavalue");
if (values.next())
values.getString("data");
else
'nothing';
values.close();
statement.close();
con.close();
