Template compatibility messages
Note: This feature is only available in OL Connect Chromium version.
This page provides information about Error, Warning, and Information messages that may be generated by the Template Compatibility dialog. Due to ongoing improvements, the messages below may not exactly match wording of the messages displayed on screen.
The messages are grouped by type. Click the type to view the messages.
Changed field and table access syntax
Description: The use of
record.fieldsandrecord.tablesis no longer array-like, and therefore thelengthproperty and numeric indexing are not supported. These collections are now plain objects.For example, this code causes errors:
Copyfor (let i = 0; i < record.fields.length; i++) {
logger.info(record.fields[i]);
}You should rewrite it as:
Copyfor (const name in record.fields) {
logger.info(record.fields[name]);
}If you need array-like behavior, use
Object.keys(),Object.values(), orObject.entries()to transform the object.Note: Detail tables remain arrays. For example,
record.mydetailtableandrecord.tables.mydetailtablecan still be indexed as before.Icon: Error
Displays: When any type of script contains the use of
record.fieldsand/orrecord.tablesin combination with the length property in the opened template.
Legacy script syntax no longer supported
Description: Scripts run directly in the content browser, so non-standard JavaScript syntax is no longer supported. For example,
String.substr(name, 1, 3), which worked in earlier versions of Designer, will cause an error. Use standard JavaScript instead, such asname.substr(1, 3), which works in both environments.Icon: Error
Displays: When any type of script contains any use of 'currently known' non-standard JavaScript syntaxes in the opened template.
Updated Syntax for scripted CMYK colors
Description: Legacy CSS syntax is not supported in this version of OL Connect Designer. The non-standard
cmyk()function is no longer available and each unique CMYK color must now be defined as a color swatch.Once a swatch is defined, it should be referenced in scripting by its swatch name rather than by constructing a color value. For example:
Copyvar color = "var(--cmyk-100-40-100-0)";Icon: Error
Displays: When any standard script or script file (internal or external) contains a legacy reference to the
cmyk()function.
Changed SVG Rendering Behavior
Description: This version of OL Connect Designer uses a new internal browser (Chromium), which renders SVG images without
<width>and<height>attributes differently. These SVGs now automatically fill the allocated space while preserving their aspect ratio.To control the size, apply a
widthorheightto the containing HTML element. The set dimensions will then also apply to images that are dynamically loaded or replaced at runtime.Icon: Warning
Displays: When the Resources → Images section contains images with the
.svgfile extension or when the HTML content contains the<svg></svg>element tags.
Detecting broken images requires post-pagination scripts
Description: The
data-broken-imageattribute is now added after standard scripts have run, but before pagination. This means you can’t use a standard script with the[data-broken-image]selector to detect broken images. To do so, use a post-pagination script instead.Icon: Warning
Displays: When any standard script (non post-pagination) contains a reference to the
[data-broken-image]selector in the opened template.
Isolated scope for user scripts
Description: Each user script now runs in its own isolated scope. As a result, variables declared with
const,let, orvar, and functions declared using thefunctionkeyword, are no longer global. They can only be accessed within the script where they are defined.To create global variables or functions accessible across scripts, omit the declaration keyword for variables (e.g.,
x = 123) and use function expressions
(e.g.,fn = function() { … }).Icon: Warning
Displays: When any type of script contains any declared variables or functions that are also used from other scripts in the opened template.
Mozilla-specific CSS properties are no longer supported
Description: This version of OL Connect Designer uses a new internal browser (Chromium), which does not support Mozilla-specific CSS properties. The
-moz-prefix, previously required for some features, cannot be used, however most related features are available in standard CSS.Icon: Warning
Displays: When the HTML, CSS, scripts contain a reference to a
-moz-CSS property in the opened template.
Opacity setting for Tint Color swatches is not applicable for non-PDF output
Description: Any Opacity setting applied to CMYK and spot Tint Color swatches is only applicable to PDF output formats. In other formats, Tint Color swatches are always fully opaque. This may cause visual differences and reduced design accuracy for non-PDF outputs.
Icon: Warning
Displays: When any CMYK color swatch and any spot colors are defined as a Tint with an applied opacity.
Postponed pagination with merge.section.paginate
Description: The post pagination script function
merge.section.paginateno longer triggers pagination immediately. Instead, pagination is deferred until the script that calls it has finished executing.Icon: Warning
Displays: When any post pagination script contains the use of
merge.section.paginatein the opened template.
Section-Related sheetConfig.positions.all properties are now write-only
Description: The section-related control script properties under
sheetConfig.positions.allare write-only. Attempting to read these values will returnnullorundefined.Icon: Warning
Displays: When any control script contains the use of
sheetConfig.positions.allin the opened template.
Updated Number and Date formatting
Description: Number and date formatting follow the latest official Unicode standard (CLDR), replacing a legacy format. As a result, you may notice differences in how numbers and dates are displayed.
For example, in certain languages, negative currency values used to be displayed within parentheses or with the minus symbol following the value (a format known as financial or accounting notation). Formatting now follows the standard notation.
Icon: Warning
Displays: Only when formatter options are used in scripts, expressions, or wizards of the opened template.
Updated Syntax for CMYK Colors and Swatches
cmyk()function is no longer available and each unique CMYK color must be defined as a color swatch.Direct references to color swatches are also no longer supported. Use the
var(--name)syntax instead, where name is the name of a color swatch. For example:Copycolor: var(--Empire\ Green);Note: Spaces must be backslash-escaped, and color swatch names are case sensitive.
When opening an older template, unsupported color references are automatically migrated where possible. However, references in read-only resources, such as remote CSS or HTML files, cannot be updated automatically.
A list of converted references, and references that are read-only and cannot be converted, is displayed with this message.
Icon: Warning
Displays: When any type of HTML, CSS, or script file (internal or external) contains legacy references to the cmyk() function or applies color swatches without using the var() function.
Read-Only content in Preview mode
Description: In Preview mode, browser content is read-only. Limited interactions, such as resizing or moving static elements, are supported. Toolbar buttons and menu items that modify content are disabled.
Icon: Information
Displays: Always
Resource names are now case sensitive
Description: Resource names, such as sections, master pages, and media, are case sensitive. When referencing a resource in a script, the case of the name in the script must match the case of the name in the Resources panel.
Icon: Information
Displays: Always
Simplified script validation in Design mode
Description: Script validation in Design mode is limited to syntax errors. Runtime warnings and errors, such as unknown table or field names, no longer appear in the Scripts panel or script editors during design. Full validation, including runtime checks, remains available in Preview mode.
Icon: Information
Displays: When any type of scripts are present in the opened template.
Text rendering differences
Description: This version of OL Connect Designer uses a different internal browser (Chromium), which renders text with slight variations. This may cause text to appear with different offsets, potentially affecting word wrapping. As a result, content that fits on a page in previous versions of the Designer might shift to the next page in this new version.
Icon: Information
Displays: Always
