Paragraph Formatting dialog
The Paragraph Formatting dialog controls how the selected paragraph is formatted. It is accessed by placing the cursor within a paragraph and then selecting Format > Paragraph on the menu.
All settings in this dialog are in fact CSS properties. Cascading Style Sheets (CSS) were originally designed for use with web pages: HTML files. Since Designer templates are HTML files, they are styled with CSS. To learn how to use CSS in the Designer, see Styling and formatting and Styling templates with CSS files. For information about specific properties and their options, see MDN Web Docs - CSS Reference.
Click the Advanced button to enter CSS properties and values directly.
The Apply button lets you preview the template with the new settings.
For information about text and how to style it see Text and special characters and Styling text and paragraphs.
Formats tab
General group:
Line-height: Specify the height of each line in the element's text, in measure or percentage. Note that this is not spacing between lines, but rather the complete height of the line itself including the text. Equivalent to the
line-height
property in CSS. -
Align: Select how text should be aligned, such as
left
,center
,right
orjustify
. Equivalent to thealign
property in CSS. -
First Indent: Specify the indentation of the first line of each paragraph in the element. Equivalent to the
text-indent
property in CSS. -
Display: Select how to display the element. This can also be used to hide an element completely using the
none
option. See MDN Web Docs - display. Equivalent to thedisplay
property. -
Direction: Select in which direction text should be displayed (ltr, rtl, auto). Useful for certain languages such as Arabic, Hebrew, etc. Equivalent to the
dir
HTML attribute.
Breaks group:
Before: Specifies whether a page break should occur before the paragraph. This is equivalent to the
page-break-before
property in CSS; see MDN Web Docs - page-break-before for an explanation of the available options. -
Inside: Specifies whether a page break is allowed inside the paragraph. Equivalent to the
page-break-inside
property in CSS; see MDN Web Docs - page-break-inside for an explanation of the available options. -
After: Specifies whether a page break should occur after the paragraph. Equivalent to the page-break-after property in CSS; see MDN Web Docs - page-break-after for an explanation of the available options.
Widows: Specifies how to handle widows within the paragraph (lines appearing alone on the next page if the paragraph does not fit on the current one). Equivalent to the
widows
property. Widows and orphans are ignored if thepage-break-inside
property is set toavoid
Orphans: Specifies how to handle orphans within the paragraph (lines appearing alone at the end of a page if the paragraph does not fit on the current one). Equivalent to the
orphans
property.
Note: For more information on page breaks, widows and orphans, see see MDN Web Docs - Paged Media.
Spacing tab
For information about spacing see Spacing.
- Padding group: Defines
padding (spacing inside the element) in measure or percentage:
- All sides: Check to
set all padding to use the Top value. Equivalent to the CSS
padding
property. - Top, Left, Bottom, Right:
Set padding for each side. Equivalent to the CSS
padding-left
,padding-top
,padding-right
andpadding-bottom
properties.
- Margin group: Defines margins
(spacing outside the element) in measure or percentage:
set all margins to use the Top value. Equivalent to the CSS
margin
Set the margin for each side. Equivalent to the CSS
margin-left
,margin-top
,margin-right
andmargin-bottom
properties.
Border tab
For information about borders see Border.
- Same for all sides: Defines
the border properties for all sides using the Top properties. Equivalent
to the CSS
border
Each group defines the following properties:
- Width: Specify the
thickness of the border. Equivalent to the CSS
border-width
property. - Style: Specify the
style of the border such as
solid
,dashed
ordotted
. Equivalent to the CSSborder-style
property. - Color: Specify the
color of the border: select a named color (defined in the Colors Properties) from the drop-down, or click the colored square to open the Color Picker dialog (Color Picker). Alternatively you could type a name or value in the Color field directly. It must be a predefined CSS color name (CSS color names), a hexadecimal color code (HTML Hex Color), an RGB color value, for example
rgb(216,255,170)
or a CMYK color value, for examplecmyk(15%, 0%, 33%, 0%)
.Equivalent to the CSSborder-color
property.
Type tab
The Type tab has all the settings for text.
- The font, font size, color and background color:
- Font: Select the font
used to display text. See also: Fonts. This is equivalent to setting the
font-family
property in CSS. Font size. Enter the size in a measure, named size or percentage. This is equivalent to setting the
font-size
property in CSS.Color: Specify the color of the text: select a named color (defined in the Colors Properties) from the drop-down, or click the colored square to open the Color Picker dialog (Color Picker). Alternatively you could type a name or value in the Color field directly. It must be a predefined CSS color name (CSS color names), a hexadecimal color code (HTML Hex Color), an RGB color value, for example
rgb(216,255,170)
This setting is equivalent to thecolor
property in CSS.Background color: Specify the background color of the text: select a named color (defined in the Colors Properties) from the drop-down, or click the colored square to open the Color Picker dialog (Color Picker). Alternatively you could type a name or value in the Color field directly. It must be a predefined CSS color name (CSS color names), a hexadecimal color code (HTML Hex Color), an RGB color value, for example
rgb(216,255,170)
This setting is equivalent to thebackground-color
property in CSS.
- The spacing between letters and words and the way the text is wrapped:
- Letter Spacing: The space between characters in a text in measure or percentage. This is equivalent to the letter-spacing property in CSS.
- Word Spacing: Set the space between each word in a text in measure or percentage. This is equivalent to the
word-spacing
property in CSS. - Whitespace: Specify how the text wraps. See MDN Web Docs: white-space for details. This is equivalent to the
white-space
property in CSS.
- The style of the text. Check any
option to apply the selected style to text within the element. This list shows the CSS property and value for each of the options:
- Bold: Sets the
font-weight
to700
. - Italic: Sets the
font-style
toitalic
. - Underline: Sets the
text-decoration
tounderline
. - Strikethrough: Sets the
text-decoration
toline-through
. - Subscript: Sets the
vertical-align
tosuper
. - Superscript: Sets the
vertical-align
tosub
. - Capitalize: Sets the
text-transform
tocapitalize
. - Uppercase: Sets the
text-transform
touppercase
. - Lowercase: Sets the
text-transform
tolowercase
. - Small-caps: Sets the
font-variant
tosmall-caps
- Bold: Sets the
