EAN-8 Settings
An EAN-8 barcodes are composed entirely of numerical data. It is comprised of 7 data digits containing the country/economic area code and an item reference code, with 1 following checksum digit.
  • General group:
  • Position group:
      The orientations would look like this (using text and a QR barcode as the examples), in a Portrait document:
  • EAN-8 Properties:
    • Height: Enter the Barcode height in either metric (cm/mm), inch (in) or point (pt) values.
    • Module Width: Specifies the width of the narrow bars. Changing this value to a higher value will generally make the Barcode bigger. The EAN-8 barcode employs a module width between 0.27mm and 0.66mm.
      • Checksum: Use the drop-down to select how to deal with the Barcode checksum:
      • Ignore: Ignore checksum calculations.
      • Auto: Add a checksum character to the Barcode if the initial value does not validate. This is the default value.
      • Check: Verify the Barcode has a valid checksum.
      • Add: Calculate and add a checksum character to Barcode, regardless of current value.
      • Print human readable text: Check to add a textual version of the Barcode data.
      • Placement: Use the drop-down to select whether to place the human readable text above or below the Barcode.
      • Font name: Use the drop-down to select the font with which to display the human readable text.
      • Font size: Enter a font size for the human readable text.
  • Process Tilde:
