PDF417 Settings
PDF417 is a two-dimensional, multi-row Barcode. It is used for encoding large amounts of data, with hundreds or even thousands of characters. It encodes alphabetic text, numbers, binary files and actual data bytes.
  • General group:
  • Position group:
      The orientations would look like this (using text and a QR barcode as the examples), in a Portrait document:
  • PDF417 Properties group:
    • Module Width: Specifies the width of the narrow bars. Changing this value to a higher value will generally make the Barcode bigger.
    • Row height: Defines the height of the bars for a single row, measured in pixels, points or metric.
    • Width to height ratio: Select the ratio of column width to row height.
    • Mode: Use the drop-down to set the compaction mode.
      • Binary: allows any byte value to be encoded.
      • Text: allows all printable ASCII characters to be end coded (ASCII values 32 to 126 and some additional control characters).
      • Numeric: more efficient mode for encoding numeric data.
      • Auto: Automatically detect the data content and encodes using the most appropriate method. This is the default option.
    • Error Correction Level: Enter the error correction level for the built-in error correction method based on Reed-Solomon algorithms. The error correction level is adjustable between level 0 (just error detection, without correction) and level 8 (maximum error correction). Recommended error correction levels are between level 2 and 5, but the optimal value depends on the amount of data, printing quality of the PDF417 symbol and decoding capabilities.
    • Rows: A PDF417 bar code can have anywhere from 3 to 90 rows.
    • Columns: The number of data columns can vary from 1 to 30.
  • Tilde processing
