UPC-E Settings
The Universal Product Code (UPC-E) Barcode is widely used for tracking trade items in stores and at the point-of-sale. It consists of 6 numerical digits which are uniquely assigned to each trade item.
  • General group:
  • Position group:
      The orientations would look like this (using text and a QR barcode as the examples), in a Portrait document:
UPC A Properties group:
  • Height: Enter the Barcode height in either metric (cm/mm), inch (in) or point (pt) values.
  • Module Width: Specifies the width of the narrow bars. Changing this value to a higher value will generally make the Barcode bigger.
    • Checksum: Use the drop-down to select how to deal with the Barcode checksum:
    • Ignore: Ignore checksum calculations.
    • Auto: Add a checksum character to the Barcode if the initial value does not validate. This is the default value.
    • Check: Verify the Barcode has a valid checksum.
    • Add: Calculate and add a checksum character to Barcode, regardless of current value.
    • Print human readable text: Check to add a textual version of the Barcode data.
    • Placement: Use the drop-down to select whether to place the human readable text above or below the Barcode.
    • Font name: Use the drop-down to select the font with which to display the human readable text.
    • Font size: Enter a font size for the human readable text.
  • Process Tilde:
