Code 128
Code 128 is one of the types of barcodes that can be added to a template; see Barcode.
This topic lists the properties and output options of the barcode type Code 128. For the properties of other barcode types, see Barcode type and properties.
Barcode properties
Module width
Code set
Set of characters to be used:
  • A: ASCII characters 00 to 95 (0–9, A–Z and control codes), special characters, and FNC 1–4
  • B: ASCII characters 32 to 127 (0–9, A–Z, a–z), special characters, and FNC 1–4
  • C: 00–99 (encodes each two digits with one code) and FNC 1
In Auto mode, the barcode generator will automatically select the correct encoding mode (set A, B or C) according to the input data.
If the barcode starts as one subset and then switches to another, set Code set to whatever the starting set is (not Auto). Enable the Tilde processing option (see below). At the position where the subset switches, add the following to the input data:
  • ~d199 to switch to subset C
  • ~d200 to switch to subset B
  • ~d201 to switch to subset A
For example, if a barcode in the format AA123456789 must start as subset B, and then switch to subset C after 1, set the barcode to be: AA1~d19923456789.
Scale
Tilde processing
Human Readable Message
When this option is checked, OL Connect shows a human readable text below or above the barcode, as defined using the Text Position, using the specified font and font size. The font size is given in points (pt).
Barcode output
Color
Output format
  • SVG: Vector format. This is usually of higher quality, but may take longer to generate.
  • PNG: Binary rasterized format. This has a slightly lower quality than SVG but is usually generated faster.
