Add/Edit PKCS#11 Module
This dialog is used to Add or Edit a PKCS#11 Module. It defines a secure hardware device (USB tokens, smart cards, or HSMs) to be used for digital signatures in Connect PDF output.
(See: Hardware for Digital Signing preferences.)
It contains the following options:
- Name: Enter a unique title for the secure hardware device. This is the name that will be used for subsequent hardware device selection thereafter.
- Library Path: Use the
Browse button to locate the DLL file associated with the secure hardware device.
- Manufacturer: Enter the name of the manufacturer if desired. This field is optional.
