Includes dialog
The Includes dialog defines which style sheets should be applied to a section when generating output (see: Styling templates with CSS files).
To open this dialog and make settings for one section, right-click the section on the Resources pane and select Includes.
The list at the left displays the style sheets that are present in the template's resources. The list at the right shows the style sheets that will be included in the output of the current section.
Use the Include and Exclude buttons to move files from one list to the other.
Files are included in the order shown. To change this order, click one of the included files and use the Up or Down button.
Note: The styles in each following style sheet add up to the styles found in previously read style sheets. When style sheets have a conflicting rule for the same element, class or ID, the last style sheet ‘wins’ and overrides the rule found in the previous style sheet.
