Job Preset
A Job Preset (or Job Creation Preset) is a settings file by which the Connect Server can filter, sort, and group print content items, add meta data and store finishing settings.
The Presets are all stored as individual files, using the selected Preset name and a "OL-jobpreset" file extension.
Once saved, Print Presets can be loaded in the Print Wizard or be used in the “Package“ option, to re-use the selected Output values.
For more information about Job Presets, see Print Presets.
Note: The Job Creation Wizard requires an active Template and associated data.
Dialog Interface
Name: Enter the name for Job Preset. This will become the preset file name, when the preset is saved.
Description: Optional description for the Job Preset.
Tip: It is recommended that you enter a meaningful description here, so how the preset is to be used can be more easily understood in the future.
Options: The following options can be used with Job Preset.
Runtime Parameters: select Runtime Parameter Options to store information which can be used at runtime for comparisons against conditions within Job Creation, or for use with external sorting programs.
Apply filtering and sorting to record selection: Check to activate the Data filtering options (to filter out certain records) and Sorting options (to sort the remaining records) pages of the wizard.
Use Grouping: Check to configure grouping of output into jobs, job segments or document sets. See Grouping options.
Override Finishing Options: Check to configure custom Finishing options, such as binding.
Include Metadata : Check to add meta data to the output. This can be done at Job, Job Segment, Document, Document Set and Page level. See Meta Data options.
Data Mapping Configuration: Use the drop-down to select which data mapping configuration this Job Preset will be based on. The data mapping configuration's model is used for field names in sorting, etc.
Click Next in this dialog to continue entering Job Preset data. This takes you to the first page of the Wizard, which is dependent upon the option selections made.
