Code 39
Code 39 is one of the barcode types that can be added to a template.
Note that barcodes of this type process tilde characters (~) in the data as special characters. See the Java4less Barcodes Guide to learn what the tilde character can be used for.
This topic lists the properties and output options of the barcode types Code 39 and Code 39 extended. For the properties of other barcode types, see Barcode type and properties.
Barcode properties
Module width
Inter Character Gap
Two adjacent characters are separated by an inter-character gap. A value of 1 means that the separator will have the same length as the width of the narrow bars (in centimeters).
Scale
Add Checksum
When checked, OL Connect will calculate a Checksum character and add that to the result of the Barcode script. If the value to be encoded is longer than 10 digits, a second check character will be calculated.
Human Readable Message
When this option is checked, OL Connect shows a human readable text below or above the barcode, as defined using the Text Position, using the specified font and font size. The font size is given in points (pt).
Barcode output
Color
Output format
  • SVG: Vector format. This is usually of higher quality, but may take longer to generate.
  • PNG: Binary rasterized format. This has a slightly lower quality than SVG but is usually generated faster.
