Code 93 extended
Code 93 extended is one of the barcode types that can be added to a template.
This topic lists the properties and output options of the Code 93 extended barcode. For the properties of other barcode types, see Barcode type and properties.
Barcode properties
Module width
Scale
                                                        Fit to box: The barcode is stretched to fit the parent box in both width and height.
Add Checksum
When checked, OL Connect will calculate a Checksum character and add that to the result of the Barcode script. If the value to be encoded is longer than 10 digits, a second check character will be calculated.
Tilde processing
Human Readable Message
When this option is checked, OL Connect shows a human readable text below or above the barcode, as defined using the Text Position, using the specified font and font size. The font size is given in points (pt).
Barcode output
Color
Output format
                                                        SVG: Vector format. This is usually of higher quality, but may take longer to generate.
                                                        PNG: Binary rasterized format. This has a slightly lower quality than SVG but is usually generated faster.
