GS1 DataMatrix
GS1 DataMatrix is one of the types of barcodes that can be added to a template; see Barcode.
About GS1 DataMatrix barcode data
In order to create a GS1 DataMatrix barcode, the barcode data must meet the following requirements.
                                                        The barcode data must start with a leading FNC1 character. Either ~1 or ~d232.
                                                        The GS1 Application Identifiers (AI) must be used for all data.
 The function code ~1 must be used as field separator for variable length AI elements.
                                                        Only ASCII characters should be used.
This topic lists the properties and output options of the barcode type GS1 DataMatrix. For the properties of other barcode types, see Barcode type and properties.
Barcode properties
Dots Per Pixels
Type the number of dots per pixel. To optimize barcode quality a Data Matrix symbol should not be printed with dots smaller than 4 pixels.
Preferred format
Use the drop-down to select the size of the Data Matrix.
Scale
                                                        Proportional: The barcode is stretched up to where it fits either the width or height of the parent box, whichever requires the less stretching.
Tilde processing
Note: The following tilde codes are supported in GS1 DataMatrix barcodes:
- ~1 = FNC1 character (for GS1 DataMatrix barcodes)
- ~2 = Structure Append
- ~3 = Reader programming
- ~5 = Macro5
- ~6 = Macro6
- ~7 = ECI expressions
Barcode output
Color
Output format
                                                        SVG: Vector format. This is usually of higher quality, but may take longer to generate.
                                                        PNG: Binary rasterized format. This has a slightly lower quality than SVG but is usually generated faster.
