USPS IMpb
US Postal Service Intelligent Mail Package  Barcodes (USPS IMpb) are used by the United States postal service for parcel deliveries. They contain parcel destination information along with other information about the delivery. They  are one of the barcode types that can be added to a template; see Barcode.
In OL Connect versions prior to 2019.2 this barcode was called "IMPB".
Note that this type of barcode processes tilde characters (~) in the data as special characters. See the Java4less Barcodes Guide to learn what the tilde character can be used for.
This topic lists the output options of the USPS IMpb barcode type. For the properties of other barcode types, see Barcode type and properties.
Note: Application Identifiers in the barcode value need to be surrounded by round brackets, otherwise the barcode will not be generated correctly.
For example, this value contains both a Postal Code Application Identifier (420) and a Channel Application Identifier 93: 420123459302234567890123456788. It should be written as follows: (420)12345(93)02234567890123456788.
More information about Application Identifiers can be found in the barcode specification here: https://postalpro.usps.com/shipping/impb/BarcodePackageIMSpec (8.0 Appendix D).
Barcode output
Color
Output format
                                                        SVG: Vector format. This is usually of higher quality, but may take longer to generate.
                                                        PNG: Binary rasterized format. This has a slightly lower quality than SVG but is usually generated faster.
