Legal Notices and Acknowledgments
Warning: OL Connect is protected by copyright law and international treaties. Unauthorized reproduction or distribution of this program, via any means, in part or in whole, may be prosecuted to the full extent of the law.
The license agreements for the associated open source third party components can be found in the following installation folder: C:\Program Files\Objectif Lune\OL Connect\Legal Notices
This application uses the following third party components:
  • Adobe PDF Library which is either a registered trademark or trademark of Adobe Systems Incorporated in the United States and\or other countries.
  • Adobe XMP Core Copyright © 1999 - 2010, Adobe Systems Incorporated. All rights reserved.
  • ASM librares which are distributed under a BSD 3-clause License
  • Bouncy Castle which is distributed under an MIT license (MIT License)
  • Dart Sass which is available for use and modification under the MIT license (MIT License).
  • DD Plist which is distributed under an MIT license (MIT License)
  • Eclipse Gemini Blueprint which is distributed under the terms of the Apache Software License Version 2.0. This product includes sub-components with separate copyright notices and license terms.
  • Eclipse Nebula This application also uses the following Eclipse Nebula components which are distributed under the terms of the Eclipse Public License (EPL) v 2.0 :
    • Radiogroup Widgets
  • Eclipse Persistence Services Project (EclipseLink), Copyright © 2007, Eclipse Foundation, Inc. and its licensors. All rights reserved. This is distributed under the terms of the Eclipse Public License Version 1.0 and Eclipse Distribution License Version 1.0.
  • Fugue Icons by Yusuke Kamiyamane which are distributed under the terms of the Creative Commons Attribution 3.0 License.
  • Gecko which is distributed under the terms of the Mozilla Public License (MPL) Version 2.0. Information on obtaining Gecko can be found on the following page: https://wiki.mozilla.org/Gecko:Getting_Started
    NOTE: This library has been modified for Connect. To obtain copies of the modified library please contact your local Objectif Lune Support team.
  • ​​Glassfish This application also uses the following Glassfish components which are distributed under the terms of the Eclipse Public License (EPL) v 2.0 :
    • HK2 API module
    • HK2 Implementation Utilities
    • Javax Inject
    • Jersey
    • Jersey Bean Validation
    • Jersey Container Jetty HTTP
    • Jersey Container Servlet
    • Jersey Container Servlet Core
    • OSGi Resource Locator
    • ServiceLocator Default Implementation
    Information on how to download the Glassfish project sources can be obtained from here: https://mvnrepository.com/search?q=org.glassfish
  • Glassfish Java Mail which is licensed under the terms of the Common Development and Distribution License (CDDL) Version 1.0. Information on how to download the Glassfish source can be obtained from here: https://wikis.oracle.com/display/GlassFish/Java+EE+7+Maven+Coordinates
  • Google Core Protocol Buffers library which is distributed under a BSD 3-clause License
  • Hamcrest Matchers Copyright © 2000-2006, www.hamcrest.org. All rights reserved.
  • HyperSQL, Copyright © 2001-2010, The HSQL Development Group. All rights reserved.
  • IcoMoon. Connect uses unmodified icons from IcoMoon (https://icomoon.io/#icons-icomoon) which have been made available under the Creative Commons By 4.0 license (https://creativecommons.org/licenses/by/4.0).
  • ICU4J 4.4.2 Copyright © 1995-2013 International Business Machines Corporation and others. All rights reserved.
  • Jacob Java Com Bridge which is licensed under the terms of the GNU Lesser General Public License (LGPL) Version 2. The source code for this can be obtained from the following location: http://sourceforge.net/projects/jacob-project/files/jacob-project/
  • Jakarta Annotation API which is distributed under the terms of the Eclipse Public License v 2.0 (EPL2). The source code for this can be obtained from the following location: https://github.com/jakartaee/common-annotations-api
  • Jakarta Enterprise Beans which is distributed under the terms of the Eclipse Public License v 2.0 (EPL2). The source code for this can be obtained from the following location: https://github.com/jakartaee/enterprise-beans
  • Jakarta Expression Language which is distributed under the terms of the Eclipse Public License v 2.0 (EPL2). The source code for this can be obtained from the following location: https://github.com/eclipse-ee4j/el-ri
  • Jakarta JSON Processing which is distributed under the terms of the Eclipse Public License v 2.0 (EPL2). The source code for this can be obtained from the following location: https://github.com/jakartaee/jsonp-api
  • Jakarta Interceptors which is distributed under the terms of the Eclipse Public License v 2.0 (EPL2). The source code for this can be obtained from the following location: https://github.com/eclipse-ee4j/interceptor-api
  • Jakarta Mail which is distributed under the terms of the Eclipse Public License v 2.0 (EPL2). The source code for this can be obtained from the following location: https://github.com/eclipse-ee4j/mail
  • Jakarta Messaging which is distributed under the terms of the Eclipse Public License v 2.0 (EPL2). The source code for this can be obtained from the following location: https://github.com/eclipse-ee4j/messaging
  • Jakarta Resource API which is distributed under the terms of the Eclipse Public License v 2.0 (EPL2). The source code for this can be obtained from the following location: https://github.com/jakartaee/connectors
  • Jakarta RESTful Web Services which is distributed under the terms of the Eclipse Public License v 2.0 (EPL2). The source code for this can be obtained from the following location: https://github.com/jakartaee/rest
  • Jakarta Servlet which is distributed under the terms of the Eclipse Public License v 2.0 (EPL2). The source code for this can be obtained from the following location: https://projects.eclipse.org/projects/ee4j.servlet
  • Jakarta Transaction API which is distributed under the terms of the Eclipse Public License v 2.0 (EPL2). The source code for this can be obtained from the following location: https://github.com/jakartaee/transactions
  • Jakarta WebSocket which is distributed under the terms of the Eclipse Public License v 2.0 (EPL2). The source code for this can be obtained from the following location: https://github.com/jakartaee/websocket
  • Java Advanced Imaging Image I/O Tools which is distributed under a BSD 2-clause License (BSD-2-Clause license)
  • Java XmlHttpRequest which is licensed under the terms of the GNU Lesser General Public License Version (LGPL) 2.1. The source code for this can be obtained from the following location: https://github.com/objectifluneCA/java-XmlHttpRequest
  • Jaxb OSGI which is licensed under the terms of the Common Development and Distribution License (CDDL) Version 1.1. The source code can be found at the following location: https://bitbucket.org/uplandsoftware/vendor/src/master/java/github.com/javaee/jaxb-v2/
  • JBCrypt library which is distributed under the ISC License (ISC)
  • Jersey which is distributed under the terms of the Common Development and Distribution License (CDDL) Version 1.1. Information on how to obtain the source code can be found at the following location: http://repo1.maven.org/maven2/org/glassfish/jersey/jersey-bom
  • Jersey Multipart which is distributed under the terms of the Common Development and Distribution License (CDDL) Version 1.1. Information on how to obtain the source code can be found at the following location: http://repo1.maven.org/maven2/org/glassfish/jersey/jersey-bom
  • JNA Version 3.5.1 which is distributed under the terms of the GNU Lesser General Public License Version (LGPL) 2.1. The source code for this can be obtained from the following location: https://github.com/twall/jna/releases
  • jQuery library which is distributed under an MIT license (https://jquery.org/license/).
  • jQuery validation library which is distributed under an MIT license (JQuery Validation licence).
  • Jsoup which is made available for use and modification under the MIT license (MIT License).
  • Little-CMS which is made available for use and modification under the MIT license (MIT License).
  • Logback which is distributed under the terms of the Eclipse Public License (EPL) Version 1.0. The source code for Logback can be obtained from the following location: https://logback.qos.ch/download.html
  • MariaDB which is distributed under the terms of the GNU General Public License Version 2. Information on how to obtain the source code can be found at the following location: https://mariadb.org/get-involved/getting-started-for-developers/get-code-build-test/
  • MariaDB Java Client which is distributed under the terms of the GNU Lesser General Public License Version (LGPL) 2.1. The source code for this can be obtained from the following location: https://mvnrepository.com/artifact/org.mariadb.jdbc/mariadb-java-client
  • Minimatch Java which is distributed under an MIT license (MIT License).
  • Objectweb ASM, Copyright © 2000-2011 INRIA, France Telecom. All rights reserved.
  • Oracle JDBC Driver which is licensed by the Oracle Free Use Terms and Conditions (FUTC) licence.
  • org.eclipse.equinox.weaving.springweaver which is distributed under the terms of the Eclipse Public License (EPL) Version 1.0. The source code can be obtained from the following location: https://github.com/osgi-forks/dynaresume
  • PDF Renderer which is licensed under the terms of the Lesser General Public License (LGPL) Version 2.1. The source code can be obtained from the following location: https://mvnrepository.com/artifact/pdf-renderer/pdf-renderer
  • Polyfills which is licensed under the Unlicense license. The source code can be obtained from the following location: https://github.com/inexorabletash/polyfill.
  • RapidJSON which is distributed under an MIT License.
  • Relique CSV Driver which is licensed under the terms of the Lesser General Public License (LGPL) Version 2.1. The source code can be obtained from the following location: https://sourceforge.net/p/csvjdbc/code/ci/csvjdbc-1.0.31/tree/
  • Rhino 1.7R4 and 1.7.7.1 which are licensed under the terms of the Mozilla Public License (MPL) Version 2.0. The source code for these can be obtained from the following location: https://developer.mozilla.org/en-US/docs/Mozilla/Projects/Rhino/Download_Rhino
  • SASS Embedded libraries which are made available for use and modification under the MIT license (MIT License).
  • Saxon which is distributed under the terms of the Mozilla Public License (MPL) Version 2.0. The source code for this can be obtained from the following location: http://sourceforge.net/projects/saxon/files/Saxon-HE/9.6/
  • Servlet API developed by Sun as part of the Glassfish project and licensed under the terms of the Common Development and Distribution License (CDDL) Version 1.0. Information on how to download the Glassfish source (as part of Java EE platform) can be obtained from here: https://wikis.oracle.com/display/GlassFish/Java+EE+7+Maven+Coordinates
  • Simple Logging Facade for Java (SLF4J) Copyright © 2004-2017 QOS.ch. All rights reserved.
  • SpotBugs Annotations which is licensed under the terms of the GNU Lesser General Public License (LGPL) Version 2.1. The source code for this can be obtained from the following location: https://github.com/spotbugs/spotbugs
  • Spring Framework which is distributed under the terms of the Apache Software License Version 2.0. This product includes sub-components with separate copyright notices and license terms.
  • StAX Utilities Copyright © 2007, StAX Utilities Project. All rights reserved.
  • Stax2 API Copyright 2010-2018 FasterXML.com.
  • Tern which is distributed under the terms of the Eclipse Public License (EPL) Version 1.0. The source code for tern can be obtained from the following location: https://github.com/angelozerr/tern.java
  • Web Services Description Language for Java which is distributed under the terms of the Common Public License v 1.0. The source code for this can be obtained from the following location: http://wsdl4j.cvs.sourceforge.net/viewvc/wsdl4j/
  • XStream Core library which is distributed under a BSD 3-clause License
  • XULRunner which is distributed under the terms of the Mozilla Public License Version 2.0. The source code for this can be obtained from the following location: http://ftp.mozilla.org/pub/mozilla.org/xulrunner/releases/latest/source/
  • zziplib which is licensed under the terms of the Mozilla Public License (MPL) Version 1.1. The source code for this can be obtained from the following location: http://sourceforge.net/projects/zziplib/files/zziplib13/
Portions of certain libraries included in this application which are distributed under the terms of the Mozilla Public License have been modified. To obtain copies of the modified libraries please contact your local Objectif Lune Support team.
Apache Software License Components
This application also uses the following components which are distributed under the terms of the Apache Software License Version 2.0:
  • Apache ActiveMQ
  • Apache Aries
  • Apache Batik
  • Apache Commons Beanutils
  • Apache Commons CLI
  • Apache Commons Codec
  • Apache Commons Collections
  • Apache Commons Compress
  • Apache Commons Digester
  • Apache Commons Imaging
  • Apache Commons IO
  • Apache Commons JCS Core
  • Apache Commons Lang
  • Apache Commons Logging
  • Apache Commons Math
  • Apache Commons Pool
  • Apache Commons Text
  • Apache Commons Validator
  • Apache Commons JXPath
  • Apache Felix and dependencies
  • Apache Geronimo
  • Apache HttpClient
  • Apache HttpClient Mime
  • Apache HttpClient Windows features
  • Apache HttpComponents Core HTTP/1.1
  • Apache HttpComponents Core HTTP/2
  • Apache HttpCore
  • Apache Log4j API
  • Apache Log4j to SLF4J
  • Apache POI
  • Apache ServiceMix
  • Apache Tika libraries
  • Apache ​Xerces2 Java Parser
  • Apache XML Graphics
  • Apache XML Beans
  • ASN1bean
  • Barcode4j
  • Gemini Blueprint Core
  • Gemini Blueprint Extender
  • Gemini Blueprint Extensions
  • Gemini Blueprint IO
  • Google Collections
  • Google GSON
  • Google Guava
  • Hibernate Validator
  • HikariCP
  • Jackcess
  • Jackson JSON processor
  • Jackson Module Jakarta Xmlbind Annotations
  • Jakarta Contexts and Dependency Injection
  • Jakarta Dependency Injection
  • Jakarta Validation API
  • Javet
  • JCIP Annotations
  • JDBI
  • JetBrains Java Annotations
  • Jetty
  • Jetty alpn client
  • Jetty webapp
  • Jetty Websocket
  • Jetty Websocket API
  • JSON Path
  • JSON Sanitizer
  • JSON Small and Fast Parser
  • Kotlin Common Standard Library
  • Kotlin Standard Library for JVM
  • Liquibase
  • LMAX Disruptor
  • Minidev
  • Nimbus JOSE+JWT
  • Objenesis
  • OkHttp
  • OkIO
  • OpenCSV
  • OpenTelemetry API Incubator
  • OpenTelemetry for Java
  • OpenTelemetry Instrumentation for Java
  • OPS4J Pax Web
  • org.eclipse.persistence.logging.slf4j
  • org.json.simple
  • OSGI
  • PAC4J
  • Sisyphsu DateParser
  • Sisyphsu Retree
  • Snakeyaml
  • SNMP4J
  • SparseBitSet
  • ​Spring Dynamic Modules
  • Swagger
  • Tika
  • ​UCanAccess
  • Woodstox
  • xalan
  • XML Resolver
Eclipse Technology:
This Software includes unmodified Eclipse re-distributables, which are available at www.eclipse.org.
The Eclipse re-distributables are distributed under the terms of the Eclipse Public License version 1.0 (https://www.eclipse.org/legal/epl-v10.html) or the Eclipse Distribution License version 1.0 (https://www.eclipse.org/org/documents/edl-v10.php).
The following disclaimer applies for all of the Eclipse Distribution Licensed libraries:
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
Eclipse Adoptium OpenJDK
This application uses unmodified re-distributables from the Eclipse Adoptium OpenJDK project. The Licenses used in that project are:
  • Build scripts and other code to produce the binaries, the website and other build infrastructure are licensed under Apache License, Version 2.0.
  • OpenJDK code itself is licensed under GPL v2 with Classpath Exception (GPLv2+CE).
  • Eclipse OpenJ9 is licensed under Several licenses.
Further Components:
  • Portions of this software are copyrighted by The FreeType Project (www.freetype.org). All rights reserved.
  • This product includes software developed by JSON.org (https://www.json.org), which is distributed under the JSON License (JSON License)
  • This product includes software developed by the Indiana University Extreme! Lab. For further information please visit http://www.extreme.indiana.edu/
