Network considerations
The following should be taken into consideration in regards to network settings and communications.
  • If a local proxy is configured (in the Internet Explorer Options dialog), the option Bypass proxy server for local addresses must be checked, or some features depending on local communication will not work.
Firewall/Port considerations
The following describes all of the ports that can be used by an OL Connect solution. IT staff may decide the firewall strategy to follow for their internal requirements and needs depending on the statements outlined herein.
Listens on
port #
Destination port #
Type
Comment
FTP Input/Output
21
TCP
Send Email plugin
25
TCP
Default SMTP port
SMTP Input plugin
25, or 587 when encryption is enabled
TCP
Email Input plugin
110
TCP
Default POP3 port
HTTPS Server
443
TCP
LPR
515
TCP
LPD
515
TCP
Secure Email Output plugin
587
TCP
Secure Email Input plugin
993
TCP
Microsoft SQL Server
1433
TCP+UDP
MariaDB/MySQL
3306
TCP+UDP
Messenger
5863/5864
5863/5864
TCP+UDP
Used for inter-module communication
HTTP Server
8080
TCP
NodeJS HTTPS Server
8443
TCP
HyperSQL
9001
TCP
NodeJS Server
9090
TCP
Telnet
9100
TCP
Connect REST Services
9340
TCP
Used for Connect REST API
Connect Server
9350
TCP
Dedicated internal connection for inter-process communication (i.e. between engines)
Connect REST API
9360
TCP
  • Port numbers in bold type are user configurable.
  • Port numbers in bold underlined type are based on the type of database used.
  • Some of the ports listed above may also be used by other modules.
  • User-configurable modules may use other ports entirely, depending on the settings defined by the end user. A few examples:
    The Create Email Content plugin will use the port defined in the Mail host setting in Workflow's OL Connect Preferences (see OL Connect Preferences).
    The ports used by the HTTP Client Input task, Legacy SOAP Client and SOAP Client plugin depend on the configured URL.
