KIX Code (PostNL) Settings
KIX code barcodes (also known as customer index code, Klantenindex, or Dutch KIX 4-State), are used by PostNL (Netherlands) for Postal code and automatic mail sorting. They contain the address of the receiver, encoded in alphanumeric format (0-9, A-Z).
KIX code barcodes are a series of vertical lines.
Sample KIX code, a series of vertical lines. Some are full height, while shorter lines are top or bottom aligned.
Tip: A KIX code can also be part of an address block created by the Address Block wizard. See Address Block.
  • General group:
  • Position group:
    • The orientations would look like this (using text and a QR barcode as the examples), in a Portrait document:
  • KIX Code Properties group:
    • Track height: The height of the small vertical centre bars, in metric (mm/cm). Value must be between 1 mm and 1.6 mm.
    • Full bar height: Height of the tallest vertical bars, in metric (mm/cm). Value must be between 4.2 mm and 5.8 mm.
      The ascender and descender bar heights are automatically calculated based upon the Full and Track bar heights.
    • Module width: Thickness of each bar in the Barcode, in metric (mm/cm). Value must be between 0.4 mm and 0.6 mm.
    • Module spacing: The spacing between each bar, in metric (mm/cm). Value must be between 0.4 mm and 0.7 mm
  • Process Tilde:
