System requirements
These are the system requirements for OL Connect 2026.1.
Operating system
Any 64-bit Windows Desktop or Server version which is in its mainstream support period, as defined by https://learn.microsoft.com/en-us/lifecycle/.
New versions of Windows are supported within the first 6 months of their commercial release.
Supported virtual environments
Amazon Web Services (AWS)
Google Cloud Platform
Microsoft Hyper-V/Azure
Nutanix AHV
VMWare vCenter/vSphere
Minimum system requirements for OL Connect / Workflow
As with any software application, these minimum hardware requirements represent the most basic hardware on which the software will run:
CPU: at least a 64-bit CPU with 4 physical cores.
RAM: at least 16 GB.
Storage: at least 100GB available on fast SSD for the system drive (by default, this means the C drive).
Networking: at least 1Gbps.
The specifications above are therefore meant as general guidelines that should produce the expected results for most implementations.
Keep in mind, however, that they may not represent the optimal configuration for your particular application.
