The OL Connect Search Program Window
The OL Connect Search program window is divided into 4 distinct sections:
  • The Program Toolbars
  • The Search Panel
  • The Results Panel
  • The PDF Viewer
Search Main Dialog
You use the Search Configuration area to configure and launch a search. The currently loaded search profile determines what search database is available in the Search Configuration area. See Determine the Currently Loaded Search Profile for help determining which search profile is currently loaded. The Document box near the top of the Search Configuration area contains a list of all documents in that database.
The contents of the Search Configuration area depend on the type of search selected in the Search type box (Basic or SQL). The Search type box at the top of the Search Configuration area determines how you define the search criteria for a search. If you select SQL, the Search Configuration area changes to accept an SQL statement.
See Perform a Search Using a Basic Query and Perform a Search Using an SQL Query for help defining searches using Basic and SQL search types, respectively.
The Results area displays the results of the last search you performed. You use it to examine and select search results. You can hide the Search Configuration area to increase the size of the Results area. See Change the View on Search Results.
