Pages methods reference
Count()
Returns the number of items (integer) in the Pages collection, in other words the number of pages in the PDF.
Syntax
Count()
Return value
Integer. The number of pages in the PDF.
Delete()
Deletes a page from the PDF.
Syntax
Delete(index)
index
Integer. 0-based index of the page to delete.
ExtractTo(destFilename, srcIndex, srcCount, optimize)
Extracts pages from the PDF and creates a new file with these pages. All relevant resources are copied with the pages. If the target file already exists, it is overwritten.
Syntax
destFilename
String. Name string of the PDF to create with the specified pages.
srcIndex
Integer. 0-based index of the first page to copy.
srcCount
Integer. Number of contiguous pages starting from srcIndex to extract.
optimize
Boolean. If true, optimize (linearize and garbage-collect) the output file.
Insert(index, mediaSize)
Inserts a new blank page in the PDF file. See also: Count().
Syntax
index
Integer. 0-based index at which to insert the page. The page is inserted before the page at index "index ". To insert a page at the end, use Pages.Count().
mediaSize
PdfRect structure containing the rectangular dimensions of the new page, in points. Cannot be undefined (null).
InsertFrom(srcFilename, srcIndex, srcCount, destIndex)
Inserts pages from another PDF file into this one. All relevant resources are copied with the pages. See also: Count().
Syntax
srcFilename
String. Name of the PDF from which pages are retrieved.
srcIndex
srcCount
Integer. Number of contiguous pages starting from srcIndex to insert. If srcCount is -1, all pages from srcIndex up to the end are inserted.
destIndex
Integer. 0-based index of the position where to insert the pages. They will be inserted before the page at index destIndex. To insert the pages at the end, use Pages.Count().
InsertFrom2(srcPages, srcIndex, srcCount, destIndex)
Inserts pages from another Pages object into this one. All relevant resources are copied with the pages. See also: Count().
Syntax
srcPages
Pages collection from which the pages are retrieved.
srcIndex
srcCount
destIndex
Item(index)
Returns a Page object from the PDF. Note that since Item() is the collection's default method, it can be omitted altogether (e.g. Pages(0) is the same as Pages.Item(0)).
Syntax
Item(index)
index
Integer. 0-based index of the page to acquire.
Return value
A Page object for the specified page. (See Page object.)
Move(index, count, offset)
Moves a range of pages within the same PDF.
Syntax
Move( index, count, offset)
index
Integer. 0-based index of the first page of the range.
count
Integer. Number of contiguous pages to move.
offset
Integer. Number of hops to move the pages. If negative, the pages are moved towards the beginning of the file. If positive, towards the end.
