PlanetPress Capture License Management
The PlanetPress Capture License Management window is used to manage the pen pack available in the installation of PlanetPress Capture. Each Pen Pack contains a limited number of pens that can be registered in the Capture Database. When the number of pens have been reached, new pens can no longer be registered.
If no pen pack is available, PlanetPress Capture functions in Demo Mode. In Demo mode, only one (1) pen can be registered in the pen management window. Also, the Capture-Fields generator will be unable to produce more than 8 documents with a pattern instead of the full 20,000 patterns.
To add a pen pack, PlanetPress must be activated using a PlanetPress Production license. if PlanetPress Production is in trial mode, no pen pack can be added because the Pen Pack uses the serial number.
Options and Controls
PlanetPress Capture Pen Licenses Group
  • Import License...: Click to open the Import License dialog. Browse to a PPLIC (PlanetPress License) file on your computer and open it to import the license. The PPLIC overwrites your current license, however it may contain more than one Pen Pack (your previous one and one you just purchased) and will display them individually.
  • License List: Displays the licenses that have been added to this system.
    • Pen License: The identification of the Pen Pack.
    • Quantity Of Pens: The number of pens that can be registered with this pack.
PlanetPress Production Group
  • Server Type: The type of server installed, normally PlanetPress Production Server.
  • Total pens: The total number of available pens on this server, each Pen Pack being added together.
