FTP Input
FTP Input tasks retrieve files from FTP sites using the FTP protocol. Masks are typically used to select multiple files to be retrieved from the server.
FTP Input connects to the specified FTP server and path, and retrieves all files corresponding to the specified mask. These files may be of any format, even formats that are not readable by OL Connect Workflow.
Files downloaded from the FTP server are processed in alphabetical order in Workflow, once the download is completed.
Each file capture by the input is sent down through the process, one at a time. When the file is finished, the process goes back to the input which feeds another file down, as long as there are files in the queue. Once all the files are gone, the task polls the FTP folder again to see if new files are present and, if so, the process continues with these files. Otherwise, the process ends.
The output to this task is a series of individual files, one after the other. These files are not modified in any way from when they are captured from the source FTP server.
- FTP Server: Enter the IP address or host name of the FTP server to poll.
- User name: Enter the name of a user account on the FTP server.
- Password: If account named in the User name box is password protected, enter the password here.
- Port number: Set to use a specific port number. Note: There is no validation to ensure the port is available. It is the user's responsibility to ensure the selected port is available and not being monitored by another application or another OL Connect Workflow task.
- Directory (optional): Enter the path of the folder to poll on the FTP server. If this box is left empty, OL Connect Workflow will poll the root directory.
- Mask: Enter a single file name mask. Multiple entries are not allowed in this box.
- Search in subfolders: Select to search in child folders of the source folder as well.
- include empty files: Check this option to accept empty files.
- Connection mode group
- Active: Select to prompt the ftp client to use the active mode when retrieving files from the FTP server.
- Passive: Select to prompt the ftp client to use the passive mode when retrieving files from the FTP server.
"Other" Tab
- Job Information group
- Backup input files: Check this to save a copy of each data file that is captured by your input. These files are saved in the OL Connect Workflow Tools working folders under the "Backup" folder.
Job Information definitions
- %1 - User name: Contains the user name that was used to connect to the FTP server. This is useful if this task is used as a secondary input and the information is defined dynamically.
- %2 - FTP Server: Contains the FTP address of the server from which the files were retrieved.
- %3 - Source file name: Contains the name of the current file that was retrieved from the server.
- %4 - Folder: Contains the FTP folder from which the current file was retrieved.
