LPD Input
LPD (Line Printer Daemon) Input tasks retrieve data in the form of print files sent from remote computers using the LPD/LPR protocol. The OL Connect Workflow LPD server starts automatically when a configuration that includes at least one active LPD Input task is started.
To prevent conflicts between competing LPD servers, you must not run any other LPD server than the OL Connect Workflow LPD server on OL Connect Workflow workstation.
LPD Input tasks are configured primarily through user options (see LPD Input plugin preferences). The only LDP information you enter in each LPD task is the queue name.
This task does not poll an input, it sits there and waits for a job file to be sent through the LPR port.
When the job is received through LPR, it is saved as a job file. No further processing is done on the file.
The task outputs the job file as is, with no evaluation or modification.
  • LPD queue names: Enter the queue name (or names, one per line) specified in the printer queue on the remote computer or computers.
  • Allow empty queue names: Check this option to accept LPR jobs that don't specify a queue name.
  • Create PDF (With Metadata): Select to output a PDF. This will only work with PostScript input.
    • Optimize Resulting PDF: The resulting PDF is optimized for size and caching options are enabled. This reduces the size of the PDFs (depending on some factors), but may take more time to output the PDF.
"Other" Tab
  • Job Information group
  • Backup input files: Check this to save a copy of each data file that is captured by your input. These files are saved in the OL Connect Workflow Tools working folders under the "Backup" folder.
Job Information definitions
  • %1 - User name: Contains the user name of the user who sent the job to the printer, or the user for which a software sending the job was logged in under.
  • %2 - Host computer: Contains the name of the computer from which the job was sent.
  • %3 - Job name: Contains the name of the job as specified by the software that sent the job.
  • %4 - Source file name: Contains the name of the job file as specified by the software that sent the job.
  • %5 - Sender's IP address: Contains the IP address from which the job was sent.
  • %6 - 6 Queue name: The name of the queue from which the job was captured. It will be empty if the queue name was empty.
