Metadata-Based N-Up
The Metadata-based N-Up action task works in conjunction with the PlanetPress Design tool's N-Up functionality. It allows to specify how many virtual pages will appear on each physical page of the PlanetPress Design template to be used with the current data file. The task rearranges the Metadata accordingly, which greatly facilitates the set up of the N-Up functionality in the design tool, especially when the solution includes duplex printing with variable data on both sides.
The PlanetPress Design document needs to be properly set up with the N-Up object and proper virtual pages in order to correctly use this task:
  • All PlanetPress Design document templates must use the N-Up object on both the front and the back pages of the duplex document.
  • Each instance of the N-Up object must have the “change data page with each repeat” option checked.
  • The total number of repeats on each page (vertical X horizontal) must correspond to the number specified in the Number of virtual pages per physical page option..
  • The Alignment setting of each n-up object must be set according to the device’s duplicating capabilities (long-edge or short edge binding).
Tip: To print a Connect template with an N-Up print layout you need an Output Creation Preset with the correct production options. See OL Connect print jobs. Also see Output Creation Preset and Print Options in Connect's Online Help.
Any data file with accompanying Metadata.
The Metadata is re-arranged and/or duplicated in order to correspond to the options set forth in this task's properties.
The original data file is output, along with the modified Metadata.
  • Number of virtual pages that appear on each physical page: This is equivalent to the N in N-Up. This number should be equal to the total number of virtual pages in your PlanetPress Design document. For example, a 2 horizontal x 3 vertical is 6-up, so this number should be 6.
  • Number of data pages that make up a single duplex virtual document: Either 1 if your document is duplex (has a front and back), whether the back has variable data or not, or 2 if your document is simplex or the data is already properly duplicated so the front and back already match.
