Telnet Input
The Telnet Input task (also known as the Raw Socket Printing Input) receives files sent to a specific port. If you want OL Connect Workflow to receive data using multiple ports, you must use multiple Telnet input tasks. To turn on or off the Telnet logging option, see the user options (see Telnet Input plugin preferences).
This task does not poll an input, it sits there and waits for a job file to be sent through the Telnet port.
When the job is received through Telnet, it is saved as a job file. No further processing is done on the file.
The task outputs the job file as is, with no evaluation or modification.
  • Port: Enter the number of the port on which OL Connect Workflow is to listen for Raw Socket communications. The default port number is 9100. Bear in mind that no two input tasks, whatever their type (Telnet, serial, LDP, etc.), should be listening to the same port.
  • Description: OL Connect Workflow displays the name of the service or process assigned to the port number entered in the Port box. Note that these are standard Internet Assigned Numbers Authority (IANA) descriptions.
"Other" Tab
  • Job Information group
  • Backup input files: Check this to save a copy of each data file that is captured by your input. These files are saved in the OL Connect Workflow Tools working folders under the "Backup" folder.
Job Information definitions
This task does not generate any job information.
