Redo a command
The Redo command can be used to redo commands that were just undone using the Undo command. For example, if you used the Undo command three times in a row and immediately thereafter decided to redo those commands, you could use the Redo command three times in a row to redo those commands. Note that all commands in OL Connect Workflow Configuration can be redone.
To redo a command:
  • From the Quick Access Toolbar, choose Redo.
