Add document
The Add document action task prepares a printer-centric PostScript job by adding a PostScript version of a selected PlanetPress Design document and the trigger to execute it before the active data file.
For more information about printer-centric printing see Printer-centric printing.
This task can support files in any emulation, however, the actual file that should be used is one that is compatible with the selected PlanetPress Design document.
This task takes the PostScript version of the document (.ps7), adds the trigger and then the active data file to it. If Metadata is present, the output is based on this Metadata (unselected data pages will not generate output, the sort order will be respected, etc). Otherwise the complete data file is merged.
The output is a PostScript job that can be sent to any output task in "passthrough" mode, for example Create PDF, OL Connect Image, etc. Metadata is not generated by this task.
General tab
- Documents: Select a specific PlanetPress Design document if you want all the jobs to be merged with that document (see PlanetPress Design documents).
- Add job information to the document: Select to prompt your OL Connect Workflow to add the available job information elements in the header of the generated file. Note that this option is only enabled if a document was selected.
