Create Metadata
Creates all the Metadata that is either the information about a data file, or the result of the merging between a data file and a PlanetPress Design document.
For more information about Metadata see: Metadata.
This task is put into effect in the following example process.
A data file in any supported emulation (see About data emulation).
If the Do not use a document (passthrough) option is used, the Metadata will contain a single Job, Group and Document level, as many data page levels as there are data pages (pages in a PDF, levels in XML, rows in a CSV, etc) in the file, and one page level per data page.
Note: In PlanetPress Design, this step is equivalent to a &metamode variable value of 1.
If a data file and PlanetPress Design document are selected, the Metadata is generated by merging the data file and document and retrieving only the Metadata generated by this merge. The Metadata levels will reflect those defined in the document, including separation for Group and Document, Metadata fields, etc. Note that:
- In PDF emulation, the size and orientation attributes for each page are set in the Metadata. In all other emulations, those attributes remain blank.
- In XML emulation, the Metadata file is always created as if the user had specified the "Second Level" parameter in PlanetPress Design.
The original data file is output, along with the newly generated Metadata file. Job Info variables are not changed.
- Documents: Select the Do not use a document (passthrough) option to create Metadata based on the data file alone.
Alternatively, as a PlanetPress Suite user you can select a specific PlanetPress Design document to be merged with the data file. Only the Metadata generated by this merge will be retrieved. - Add job information to the document (only if a document was selected): Select to prompt OL Connect Workflow to add the available Job Information elements in the header of the generated file.
