File Name Condition
File Name Condition tasks test the original name of the job file traveling down the process branch, or in other words, the name of the file received by the last input task appearing above the condition.
  • File name mask: Enter one file name mask or multiple masks separated by a semicolon (;). See Masks. The condition will be tested True only in the case of an exact match, so consider using wildcard characters.
  • Invert condition result: Select to toggle the result of the condition (true becomes false and vice versa).
