Input SOAP
Note: The Input SOAP plugin and SOAP Client plugin replace the Outputs-SOAP Client plugin which has been moved to the Legacy group.
The Input SOAP task is used to answer calls from a remote SOAP client and to return a response to that request. It is similar in functionality to the HTTP Server Input task and NodeJS Server Input task.
The Input SOAP task only responds to a single SOAP action by the client: SubmitJob. Within this request however, a secondary action (SubmitSOAPActionName) can be specified - this is what the SOAP Action corresponds to in this task's properties.
Note: SOAP communication is non-trivial and requires a certain understanding of XML and the SOAP protocol. Using the SOAP tasks pre-supposes this knowledge and this documentation does not attempt to provide it.
For more information about SOAP workflows, see SOAP workflows.
This task does not poll any location by itself. It sits there waiting for requests coming in through WSDL (SOAP communication) and, when it receives a request, runs the process and returns the last output generated by the process to the client.
No processing is done. The request that is received by this task is XML and it is maintained as such.
As with the HTTP Server Input, this task has a dual-output purpose. First, when the initial input task is run, the XML request is output onto the process. Then, when the process is finished, the last job file generated by the process is returned to the requesting client.
  • SOAP Action: The SOAP action is used with the SubmitJob action. It’s the equivalent of the process name. The difference is that more than one process can share the same SOAP action. That way more than 1 CPU can be used to process all the incoming requests; however, this means that all processes sharing the same SOAP action must be identical because there is no way to decide the execution order of all the processes.
"Other" Tab
  • Job Information group
  • Backup input files: Check this to save a copy of each data file that is captured by your input. These files are saved in the OL Connect Workflow Tools working folders under the "Backup" folder.
Job Information definitions
  • This task does not generate any job information.
