Merge Jobs
The Merge Jobs Action task merges an external Metadata file containing an OL Connect Job with the current Job File.
The task must receive a Metadata Job File, which is output from the Create Job task. The selected Metadata file must also be the output of a Create Job task.
The current Metadata Job File is merged with the selected external Metadata file.
The task outputs a merged Metadata Job File which can be used in the Create Output task.
  • Metadata file: Enter the full path to a valid Metadata file containing an OL Connect Job, or use the Browse button to browse to a valid location.
