Legal Notices and Acknowledgments
Warning: OL Connect Workflow is protected by copyright law and international treaties. Unauthorized reproduction or distribution of this program, via any means, in part or in whole, may be prosecuted to the full extent of the law.
This application uses the following third party components:
  • Adobe PDF Library, which is either a registered trademark or trademark of Adobe Systems Incorporated in the United States and\or other countries.
  • DCPcrypt Cryptographic Component, which is made available under the MIT License.
  • DIMime, which is licensed under the terms of the Mozilla Public License (MPL) Version 1.1. The source code for this can be obtained from the following location: https://www.yunqa.de/delphi/products/mime
  • Expat library, which is made available under a MIT License.
  • FastMM, which is licensed under the terms of the Mozilla Public License (MPL) Version 1.1. The source code for this can be obtained from the following location: https://github.com/pleriche/FastMM4
  • Indy, which is distributed under the Indy Modified BSD License: https://www.indyproject.org/license/bsd
  • Jedi Code Library, which is licensed under the terms of the Mozilla Public License (MPL) Version 1.1. The source code for this can be obtained from the following location: https://sourceforge.net/projects/jcl/files/JCL Releases/
  • Jedi Win API Library, which is licensed under the terms of the Mozilla Public License (MPL) Version 1.1. The source code for this can be obtained from the following location: https://sourceforge.net/projects/jcl/files/JCL Releases/
  • JSON Delphi Library (ulkJSON) library, which is distributed under a BSD 3-clause License.
  • LibJPEG, this software is based in part on the work of the Independent JPEG Group, which is licensed under the following terms: LibJPEG license
  • LibPNG, which is licensed under the following terms: PNG Reference Library License version 2
  • LibTIFF, which is licensed under the following terms: LibTIFF License
  • Node.js, which is made available under the MIT License. Node.js also includes external libraries that are available under a variety of licenses. See LICENSE for the full license text.
  • OpenSSL Toolkit, which is licensed under the following terms: OpenSSL licensing
  • PerlRegEx, which is licensed under the terms of the Mozilla Public License (MPL) Version 1.1. The source code for this can be obtained from the following location: https://github.com/TheDelphiCoder/PerlRegEx
  • PocketSOAP, which is licensed under the terms of the Mozilla Public License (MPL) Version 1.1. The source code for this can be obtained from the following location: https://github.com/superfell/pocketsoap
  • RapidJSON, which is distributed under an MIT License.
  • SQLite, which is licensed under the following terms: SQLite License
  • TurboPower Abbrevia, which is licensed under the terms of the Mozilla Public License (MPL) Version 1.1. The source code for this can be obtained from the following location: https://github.com/TurboPack/Abbrevia
  • TurboPower Async Professional, which is licensed under the terms of the Mozilla Public License (MPL) Version 1.1. The source code for this can be obtained from the following location: https://github.com/TurboPack/AsyncPro
  • TurboPower SysTools, which is licensed under the terms of the Mozilla Public License (MPL) Version 1.1. The source code for this can be obtained from the following location: https://sourceforge.net/projects/tpsystools/
  • WinSCP, which is used by the SFTP input/output plugins and is distributed under both the GNU General Public License (GPL) version 3, and the Mozilla Public License (MPL) Version 2.0.
    For more information on WinSCP, see https://winscp.net/eng/docs/introduction.
  • WinSW (Windows Service Wrapper), which is licensed under the MIT license.
  • zlib data compression library, which is licensed under the following terms: zlib license
Eclipse Adoptium OpenJDK
This application uses unmodified re-distributables from the Eclipse Adoptium OpenJDK project. The Licenses used in that project are:
  • Build scripts and other code to produce the binaries, the website and other build infrastructure are licensed under Apache License, Version 2.0.
  • OpenJDK code itself is licensed under GPL v2 with Classpath Exception (GPLv2+CE).
  • Eclipse OpenJ9 is licensed under Several licenses.
VSS Java FreeMarker:
This product includes software developed by the Visigoth Software Society (http://www.visigoths.org/).
This includes the following subcomponents that are licensed by the Apache Software Foundation under the Apache License, Version 2.0:
  • freemarker/ext/jsp/web-app_2_2.dtd
  • freemarker/ext/jsp/web-app_2_3.dtd
  • freemarker/ext/jsp/web-app_2_4.xsd
  • freemarker/ext/jsp/web-app_2_5.xsd
  • freemarker/ext/jsp/web-jsptaglibrary_1_1.dtd
  • freemarker/ext/jsp/web-jsptaglibrary_1_2.dtd
  • freemarker/ext/jsp/web-jsptaglibrary_2_0.xsd
  • freemarker/ext/jsp/web-jsptaglibrary_2_1.xsd
HyperSQL
Copyright (c) 2001-2024, The HSQL Development Group
All rights reserved.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL HSQL DEVELOPMENT GROUP, HSQLDB.ORG, OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
For work originally developed by the Hypersonic SQL Group:
Copyright (c) 1995-2000 by the Hypersonic SQL Group.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE HYPERSONIC SQL GROUP, OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
