Change the Interface language
OL Connect Workflow can be used in multiple languages, and the list of available languages grows as we translate the software. The first time you use OL Connect Workflow, it starts in the language used for the installation.
To change the language used by the OL Connect Workflow Configuration program:
- Click the OL Connect Workflow button, then click Select Language.
The Select Language dialog box appears. This box lists all the languages that can be used by OL Connect Workflow as well as the Use System Default Locale check box. - Select the desired language.
 - Use System Default Locale: Select to mirror your language settings, as defined in the Regional and Language Options of the Windows Control Panel. This option is typically used to enter and process information in non-European languages. It is only enabled when English is selected as the program language.
 - Click OK.
You may change this setting as often as you like, but you need to restart the application every time you do so.
Note: If you plan to enter and process information in non-European languages, you should know that OL Connect Workflow uses codepages when storing and retrieving information (a codepage is a mapping used to convert back and forth the letters and numbers used by humans to the numeric characters used by computers). By default, codepage 1252 is used for Latin languages (good for Afrikaans, Basque, Catalan, Danish, Dutch, English, Faroese, Finnish, French, Galician, German, Icelandic, Indonesian, Italian, Malay, Norwegian, Portuguese, Spanish, Swahili and Swedish) and codepage 932 is used for Japanese.
