Decompress File(s)
This task can be found in the Plug-in Bar, under the Action tasks group.
Decompress File action tasks decompress zipped job files (files compressed as zip files).
This task only accepts ZIP files, however it is not necessary that the job file be the ZIP, since this file path and name can be specified in the task itself.
Every file in the ZIP is extracted to the specified location. If a folder structure exists in the ZIP, it is respected in the output folder.
This task outputs the data file it received with no modification. Metadata and job files are not touched either.
  • Zip file name: Enter the name of the zipped file. In this variable property box, you may enter static characters, variables, job information elements, data selections, or any combination of these.
  • Output folder: Enter the name of the folder in which you want the decompressed files to be stored.
  • File mask: Enter a file name mask to specify which files must be decompressed. Leave the default value of *.* to decompress all the files found within the zip.
  • Password: Enter a password if the zip file is password protected.
  • Restore path structure: Select if you want the complete file structure to be rebuilt from the output folder to the decompressed files.
  • Force directories: Select if you want to allow the system to create new folders when required. If this option is not select and the Decompress file action task tries to save a file to a folder that does not exist, the task will fail.
  • Overwrite existing files: Select if you want decompressed files that have the same name as existing files to overwrite the existing files.
