PlanetPress Suite - Download to Printer
Download to Printer Action tasks are used to warn printers that the files that will be sent to them are to be stored to a specific location rather than printed. Note that each Download to Printer Action task must be followed by a Printer Queue Output task set to "pass-through", in order for it to be sent to the printer and not merged with a PlanetPress Design document.
You can use Download to Printer action tasks to send various types of files, such as attachments, documents and fonts that are used in PlanetPress Design documents that are executed directly on the printers (see PlanetPress Design documents and About printing).
For images you should rather use Send Images to Printer action tasks (See PlanetPress Suite - Send Images to Printer), as they provide image quality and conversion options.
Any file that you wish to upload to the printer. Note that this task does not attempt to verify that the type of file being sent is compatible with the printer, or is in a supported file format.
The currently active data file is converted into PostScript.
A PostScript file containing the necessary code to save the data file on the hard drive.
- Hard disk name and path (as required): Enter the name and path of the hard disk to which the file is to be saved (enter “%disk0%/PPFiles/Resources”, for example, to save the file to the folder [ROOT]/PPFiles/Resources located on a hard disk identified internally as “disk0”). Leave blank to save the printer’s default hard disk and path.
- File name: Enter the name under which you want the file to be saved. By default, this property is set to “%o”, so the file is saved under its original name (this is often the best choice, for items such as font files, for instance).
- File name case:
- Do not modify: keeps the character casing of the file name as is.
- All uppercase: changes all characters to upper case (README.TXT, for example).
- All lower case: changes all characters to lowercase (readme.txt, for example).
- Keep file extension: Select to use extensions when saving files. When this option is selected, if the task receives a file with the “txt” extension, for example, it will keep this extension even if it renames the file (as specified in the File name box).
- Print confirmation page: Select to print the Variable content document download confirmation page when the download is successful.
