File/Folder Condition
This task can be found in the Plug-in Bar, under the Process logic tasks group.
The File/Folder Condition tasks checks if the specified file or folder exists and returns true if it exists, or false if it doesn't exist.
- File or folder to check: Enter one file or folder name. The name may contain text, variables and data selections (see Variable task properties). The Browse button allows to select a file or folder on disk.
Advanced properties
Right-click the task in the Workflow process and select Advanced Properties... to make settings on the On Error and Miscellaneous tabs.
