File Size Condition
This task can be found in the Plug-in Bar, under the Process logic tasks group.
File Size conditions test the size of the job file they receive. Note that the job file may include data selections, attachments and documents that were added by other tasks. If a file does not exist, it's file size will be 0kb.
This task is put into effect in the following example process:
- File size is: Select whether the condition is to check if the job file is smaller (less than) or larger (more than) than the specified value.
 - Kbytes: Enter the minimum (more than) or maximum (less than) size setting in kilobytes.
 - Invert condition result: Select to toggle the result of the condition (true becomes false and vice versa).
